It would need airflow. Any blocking of vents would reduce that. Column above/below vents allows convection, which will be smoother and more effective without baffles in the way. I wouldn't think a dongle would matter much.
Hello
Agree about needing airflow.. and top and bottom and far right edge will have plenty, its just the L side where the dongle is, that I have limited space.
I spoke with another expert, and he said the 2 inch gap required L-R from the unit is from the edge of the Metal box, since the dongle extends 1.25 inches, a 2 inch clearance will not interfere with that , and I can install/remove the dongle from that gap. So.. plan is to leave a 3 inch gap beyond the metal case, which exceeds the requirement, but doesn't include the 1.25 inches of the dongle (or more like 4.25 inches,) which is space I really don't have on my basement wall , in the logical area to install the solark, and transfer switch.
One of the youtube installers stated that Solark promises that you don't need the transfer switch, as the "pass through" of the 200A service will continue to work if the solark goes down hard or becomes inoperative.
Not needing the transfer switch would simplify my install, but I keep coming back to a nightmare scenario where the solark is dead, or needs to go somewhere for service, and my main 200A feed for my entire home will need to be disconnected, and re-connected to bypass the solark and feed my mains panel. I found a brand new 200A transfer switch online for $50, and I am going to go ahead and install it, then if/when anything bad happens , wife, or future owner can just flip that switch, and the main panel is back direct connected to the grid.
Thanks for your reply.. and now I just need to find a local electrician to help me install the main fused 200A cut off switch code requires to feed the solark. Wish me luck with that, I call, leave messages, with a clear statement of what kind of help I need, and very few electricians, answer the phone, or call back.. just endless messages.
CPU
I
