MaikaiLifeDIY
I'm looking to get a quick thread going for all the Sol-Ark 15K owners to provide any information they have so I can compare. I've been working on a low current issue affecting my SOC and immediately after installing a Victron Shunt in front of the Sol-Ark, I'm noticing what seems to be a consistent 50 (ish) watts of power difference. Higher on the Victron Shunt than what the Sol-Arl is reading for its battery consumption.
I have a tiny load, just a single full-size refrigerator running with 60kWh of EG4 LifePo4 Battereis supplying the inverter.
My guess is that the 50w difference is the actual consumption of the Sol-Ark, but the manual says this should be closer to 90w. So I'm wondering if anyone else can provide any numbers if you happen to track your actual consumption in front of the Sol-Ark with a shunt, and what the difference might be.
I'm using the Victron Smartshunt 500amp with the latest I think 4.14 firmware and the Sol-Ark has version 7.2.2.2 which I believe is the current firmware.
