hpeyerl
- Mar 22, 2022
- 93
This is a new system that I've just finished putting together. I have a few minor things to do still (Gen hookup, Gen start, etc).
System config is:
* 27 x 505w panels.
* Tigo TS4-A-O optimizers/RSD
* Sol-Ark 15k
* 8 x 100AH Shoto telecom rackmount Lifepo4 batteries
Yesterday I reconfigured the work mode on the inverter so I could enable TOU. That caused the inverter to reboot and everything went dark for a "wtf have I done!?!?" really long 3 or 4 minutes. Then everything came back and was working fine; however after everything came back, Solar-Assistant (and PowerView) were showing 0 load, 0 grid, and 0 PV. As I was trying to understand what happened it suddenly started logging consumption. I wrote it off as an aberration.
This morning I woke up to look at Solar-Assistant and all night long, there was no Load or Grid data. Then all of a sudden it started working again.
I realized that when there's no PV generation, the inverter doesn't seem to show any consumption on the Load nor any Grid consumption. It's not just Solar-Assistant either, PowerView also shows the same; so I'm sure it's not my RS485 or anything like that.
Is this just a side effect of the system being in "Limited power to Load" work mode? I'm not sure I fully understand how to configure TOU so I could have done something wrong.
System config is:
* 27 x 505w panels.
* Sol-Ark 15k
