timselectric
- Feb 5, 2022
- 18,730
Yes, a ground is required.Follow up question:
A few of you mentioned a ground wire in the conduit from array to inverters.
1) Should I have a ground wire in the array conduit?
2) If yes, what gauge, and what do i connect it to in the inverter area?
thx
12 gauge would be sufficient. But I would make it 10 gauge.
It would connect to the solar panel frames and any metal racking.
At the house end, it connects to the rest of your grounding system. (Inverter, loads panel, and whatever else you have)
