I am in the process of planning out how to get pv wire from inverters to the solar arrays. The distance is 450 feet.
I have concluded with advice from others that
I need to use 8AWG (8 guage), pv rated wire.
I will have 16 total wires, each 8awg, going thru the conduit.
If I use schedule 40 pvc the pipe is going to be around $1,300 not including elbows, etc., but that is the proper method in my opinion.
I calculated area of 1 8awg wire, multiplied by 16, and determined that 1-1/2” should give enough cross sectional area to pull 18 wires, and include room for a nylon pull string.
But it would save a ton of money, almost $1000, if I used non-perforated culvert pipe and have extra room in case i want to run 4 more solar strings in the future.
But it may not keep water out, although i would amply caulk all joined sections.
What are the consequences, that I may not perceive of using culvert pipe.
Open to any
