I currently have:
Grid tied ~6.7Kw Enphase system: 19 IQ7+/Panels@355W (47.45VOC/9.69ISC), 13KWh Encharge . Self-consumption only, no Smart Switch. All currently working fine.
Challenge:
I am looking for a backup solution in the event of failed Enphase "system" or if I need to forklift my array off-grid in an emergency.
In the event of failure/emergency:
I would like to take my (up to) 19 panels and plug them into an Ampinvt 80A MPPT Solar Charge Controller (SCC) @48v. (This was based on price/review). I would have six parallel "arrays" of 3 (series) panels to keep the series voltage just below 150V (controller max PV input) ~142.35V. This should max out at just under 10A per string or ~60A for all six strings
I have about 60 new 12V 5Ah batteries. Still spec'ing required wiring: Most likely six sets of 10' 12AWG MC4 cables to a 6-string solar MC4 prewired combiner box. Then 4AWG to my MPPT. Figuring out battery wiring solution for heat/load.
Couple of questions:
1) If I set charge controller for 48V and wire the batteries for 48V, will my load output from the SCC be 48V? I found mixed results from searching internet. I have an existing 4KW Pure Sine Wave Inverter but it takes 12V only. I do not want to use a DC-DC (48-12) converter or purchase another inverter.
2) If output is 48V based on battery voltage, maybe some recommendations for combo 80A (or larger) MPPT SCC/Inverter under $1K
3) Please provide any other input/recommendations from experience
Thank you in advance
Challenge:
