craigcabrey
- Jan 8, 2022
- 18
Hi all,
I realize this topic has probably been done to death but just want to get clarification. I know that using multiple charge sources isn't a problem. However, is it a problem to use a charge controller in conjunction with an all-in-one unit such as the LVX6048? I imagine not since behind the scenes it's just a charge controller as well. But the LVX6048 can also charge from the grid if needed. Would that conflict with a separate charge controller in some way?
My front porch can only fit 6, west facing panels (I have 8 on the way). Thinking about setting up the other two south facing and running them through a charge controller directly to my EG4 48V pack. For this, I imagine the Victron 100/20 MPPT charge controller would be perfect. Panels are G10+ 395W Q Cells, so open circuit is rated at ~45V, MPPT voltage at ~36V.
Thanks!
Thanks!
