Since my solar/electrical system went live my FM radio reception has tanked. In the city here I've always had perfect FM reception for local stations, even after a cabover camper was installed on my Tacoma. Some stations will come in fine at one location but then fade in and out within a few miles drive. Others won't come in at all now. Radio is all but unusable right now.
XM Satellite is pretty bad too. It had some issues before in spots like mountains/forests/downtown where sky is obstructed but it is that bad everywhere now. When the signal is there it is clear, but it cuts in and out constantly every time I pass a big rig, tree, overpass, or any other obstacle. It was never this bad before.
As background on my truck/camper setup I have a 2019 Tacoma double cab. The camper is a Superpacific Switchback X1 which is a wedge roof top tent integrated onto a truck topper. I've installed two Renogy 100W flex panels on top. In the front of the bed I have a Renogy DCC50S charge controller, Renogy 100Ah LiFePO4 battery and Giandel 1200W pure sine inverter. 4awg cables run to the panels on the roof and to the alternator, 15-20ft of cable each. The inverter has been powered off so it is likely the interference is coming from the cables or the charge controller.
I've read about solar cables and MPPT controllers causing RFI (radio frequency interference) but those discussions all seem to center around Ham radio and VHF signals on boats. Anyone with solar panels up on their vehicle experienced this, and were you able to address the issue? My Tacoma has a shark fin antenna below the camper overhang. Would relocating that antenna likely solve the issue? Or perhaps installing a new antenna or some sort of signal booster? Something else I can try?
Thanks for any input!
