Recently installed an off-grid system in my house with Make Sky Blue 6.6KW inverter and 9.6KW LifePO4 battery pack.
When running the washing machine I can see LED light flickering issue.
I don't think this is happening due to the battery or battery cable because there is no issue with the electric geezer and Air conditioner (Those consume more power than the washing machine). It seems this is happening when the more powerful motor is running (In the washing machine and the blender)
There is no issue when running with utility power (which also comes through the inverter)
The distance between the inverter and the main board is around 10m. But there is no option to change the inverter location or main board location due to the installation cost and other difficulties.
How do I isolate if is this an issue in the inverter or load wire (main board -> inverter and vice versa) or something else?
