There is no need to "apologize" and I can't see any grief against you in the contributions. Maybe Germans have another culture to consider engineering, there is possibly a reason why they make good cars?
If the leading aspect of your design is to keep in line with your residential park's constraints, then this will rule and you don't need a lot of maths upfront. The databases will tell you how much you can expect to harvest with the given situation.
The open question remains: what will you do with the harvested energy? Can you feed the excess back in the grid?
Is your focus more on reducing cost, ecological considerations, or on "prepping"?
So you will mainly have too much sun most of the time anyhow, maybe you want to consider a bit of ventilation to avoid stowing heat between the panels and the carport, since you cannot tilt them enough?
P.S. the fascinating thing about solar energy, is that it is much more than " plug and play " or just piling up kilowatts. Every individual solution is different.
I live in the San Franciso Bay Area, a 40-mile Radius around S.F. I'm 29.5 miles due East of San Franciso, in the Livermore/Pleasington/Dublin valley. It doesn't get cold here but very hot. between 95F to 110F almost every day during June through the end of September. Here it is at the end of October and it is still in the '90s
With respect to my panels, I have no option where to place them. The only option I have is the tilt angle and that too is restrictive due to the mobile park I live in. If the panels look like a sore eye, I will be forced to take them down.
So it is very important that I can keep them as invisible as possible, but still get enough sunlight energy, which I measure in lumens and not what you see on graphs or charts which are in radians. If I know how many lumens the sun puts out, I can determine the percentage of useful energy from the sun to supply power to my controller to run the load of my house. I use lumens because I have a lumen meter, but not a meter that can measure the strength of the sun in other units.
Anyway, it looks like I'm getting a bunch of flakes for my show and tell article. I guess I better not do that again. - wow!
Yes, I do have two problems with respect to where and how to mount my panels. one is just what you said, the heat buildup between my metal carport roof and the solar panels. So need to work on ventilation as in the summer time, 100 plus degrees is average here.
With respect to too much solar power (energy), I may not have enough to charge my batteries after running the house all night after the sun goes down. At least according to my Solar dynamic semulator I created in Excel. But I won't be installing my system until next spring as I don't have the money right now to by the expensive battery(s).
I know I'm doing a lot of extra unessussary work, but I got the time to play around with it while it is setting on my workbench. Everything is connected expect for the panels and I'm using to junk yard 12 volt batteries. I'm using a 268 watt floor fan for my load ac load and letting everything run. - My house uses on the average 350 watts in the day and less that 150 watts after I go to bed. It takes about 30 minutes for the batteries to run the fan before they reach their low voltage point and the Utility power takes over to continue runing the load and recharging the batteries.
Anyway I'm having fun and keeping this old brain working and of the counch watching TV all day.
Anyway, that's the name of that story.
