Crazy Pirate
- Nov 15, 2019
- 3
I have 2 solar panels in parallel each rated for 31.5 volts @ 9.45 amps. This panel pair goes into a Victron 100 volt 50 amp MPPT controller and then out to my 12v battery bank. I monitor this solar panel pair using the Victron connect bluetooth app. This has been working just fine until a few days ago. Nothing has changed but now this panel pair in full sun (no shading) is showing a higher battery voltage (14.45v) (actual battery voltage is 13.7v) and goes into float generating 1 or 2 watts of power.
I have a second pair setup identical to the first and under the same conditions and at the same time the second pair is generating 240w vs the first pair at 1w.
Can you or anyone point me in the right direction for a solution.
Thanks
Capt Dave
Reply
Thanks
Capt Dave
Reply
