That looks like the normal layout. Top left is your panels generating juice. Top right is the grid. Bottom left is your batteries. Bottom right is your household usage.The 'leaf' circle has disappeared and the 'lightning bolt' circle has moved from mid right to bottom right. All makes perfect sense . . . not!!
The battery will charge from the grid if the charge level gets below a set level. This is to protect your battery from damage.Hi - I am a new user too. Find the app odd in some respects - direction of flow to the grid, for example seems the wrong way round. However, I get this "green spike" that i see on your image. I assumed that the system is drawing a bit of electricity from the mains in order to keep the battery around 20% over a longer-term period. Is that right? Lately, with longer days, more sunshine, I have not had what I assume is the "charging spike".
Yeah, the figures are all over the place. It seems to be adding my import on top of the actual consumption.At no point today have we pulled anything near 1kW. Total yield top left is correct, 3.1 is about right for today so far. But then if you look at Generation it says 7.7kWh?? Huh whats going on? It's like it thinks the battery is generation or something - I can't figure it out.
Your datalogger is fine, but the fixing for the socket it plugs into has come loose inside. You'd probably need to open the inverter to fix it, which could be dangerous. Best just leave it alone and be very careful if you unplug the datalogger. Don't let it twist too much or it could break the wires.On a site note - I wonder if my data logger's damaged because the green port on the underside of the inverter swivels and pretty sure it's not meant to.
Agreed, your datalogger appears fine. But what your PV CT is reading seems way off. You should see something more like this.
I'd start with a visual inspection of where your CT is located and it's direction. Note, the CT from the Solis should be located between your panels/inverter and your load/grid - with the arrow pointing towards the grid.
Check in settings that the CT is set as PV. If the CT has been installed the wrong way, there is an option to reverse it in the settings.
Reposted my reply as an independent comment below, deleting from here...I have had this (small) system (8 panels x 1 battery) for 3 weeks. The Solis app – is simply not fit for purpose.
The ‘app’ does not show correct information and they admit it is not correct, they are telling me that what I see on the app is not what is happening. 2. The user manual for the app does not look like what I see on the app screen. I ‘raised a ticket’ with Solis and the agent is unable to explain to me what is going on possibly (?) because his English (reading/writing) is not adequate.
How can they sell a system knowing that the app to control the system is not fit for purpose?
Solis sales/service etc., Bootle, Liverpool don't answer the phone ever, every day, never!!
Disgraceful service
