Reporting this as an independent entry, didn't know how to do that before...
We had a Solis system installed 2 weeks ago, 14 panels, East/West split. The number being reported in the app were completely bonkers and we could not figure it out. We read about various app problems so we kept reloading etc and saw some of the changes already mentioned on this forum. But the basic problem remained. We did not install a battery, as we want to size the system first. This made the diagnosis of our problem maybe a little easier.
We saw 2 main types of problems:
1. When is was quite sunny, we would get 3-4Kw being reported as generated, but we'd also see 2-3Kw being imported from the grid, and the house consuming the sum of these, maybe 6-7Kw. This is early evening with no appliances at all running.
2. At a cloudy time, we would see maybe .5Kw being generation, and maybe 2Kw being exported to the grid, so exporting more than we were generating.
So, turns out the sensor (collar) that detects the current to the grid was on the wrong way around. And the house consumption figure is calculated by adding the other 2 numbers, it's not measured independently. So the system saw 2-3Kw going to the grid but measured that as 2-3Kw coming from the grid, added that to the amount being generated, and said that 6-7Kw was being consumed by the house.
In the second case, we were importing 2Kw to supplement the 0.5Kw being generated, but the system reported that as an export of 2Kw, and reported that the house was using 0Kw.
Turns out this is a common problem, and the engineer was able to go into advance settings on the Inverter and switch the orientation of the sensor in software, no wiring changes required at all.
Not sure if this could be the problem that others are seeing, it seems obvious in hindsight, but took a few weeks of pondering to arrive at it.
