ToddParker
Hi all. I have some roof mounted residential panels in 3S arrays that are 120v that I feed into a Bluetti AC500. I'd like to also be able to use these panels with smaller power stations like the Delta Max or Anker Solix 2000 but it seems that most midsize power stations are moving towards a 60v limit which is pretty tricky to get optimized panels wired up.
I'm curious if there are relatively efficient options for buck converting 100-150v arrays down to 60v. Bluetti sells a (very expensive) PV step down module that converts arrays up to 550v down to 120v which won't work here but that's the general idea. Any recommendations?
PV VOLTAGE STEP DOWN MODULE(D300S)
Applicable Models: AC300/EP500/EP500Pro Function* Step down the voltage of rigid panels to 120V from 550V* Support 3000W Max input* 3000W Max output* IP54 Click To Download Bluetti D300S User Manual
www.bluettipower.com
