This is where all my solar components & electric breaker boxes will be mounted. Next I have to drill out the mount holes on the Midnite ? The holes aren't big enough for the smallest strut nut (1/4'). Just barely to small.
If I was to do it again I'd cut the strut longer, up the the ceiling. Then the strut would be forced flat instead of being backed by the bend in the tie down. I had a bit of fumbling that would have prevented.
I had to drill the holes out to work with strut nuts. It was kinda a pain to tighten the top bolt. Better way might be to use a smaller bolt & fab the nut. But, it’s not going anywhere.
