Steve_S
Offgrid Cabineer, N.E. Ontario, Canada
Just finished another system install using a Midnite Baby BigBox and their latest Polarized Breakers and VOILA a GOTCHA ! Not a Good One either !The Midnite is pretty much plug and play.
You have to buy the breakers and install them but other than that just connect your battery.
The class T fuse at the battery.
Now that isolates the battery.
I suppose you could put Anderson or something similar for a quick disconnect.
They made a "slight" change with the breakers and they no longer have "grabber" ridges in the clamp so they don't "bite" the wire to hold it. It's NOT an "end of world" thing by any means BUT makes fiddling around tougher cause you CAN pull the wiring free even when tightened down well.
A penny pinching thing ? Does not make sense... Why remove the Grabber ridges...
One thing that is FINALLY catching on in North America is the use of DINrails and boxes that support them... Old Hack in Europe & Asia and has taken forever (so it seems) to get to NA but they are here now... ANY DINRAIL box can serve... There are also a lot of bits that can use DIN without needing a box at all... IE "Marettes" are finally finding Retirement in North Ameria too ! That only took 20 some years to catch up...
