Swamplizard
Ready to unplug and wander the USA
- Oct 21, 2020
- 238
Conversion Van project has 3x100Watt in series on drivers side and identical setup on passenger side (separate series for when I have a kayak on one side of the roof).
Having a LOT of MPPT reliability issues with LV2424 and it eats a lot at idle so looking for a supplemental MPPT to feed the 24-volt 280AH LIFEPO4 bank for when I have the LV2424 turned off (Like when Van is being stored outside but not being used).
Question #1: Can I simply add an MPPT and move the solar inputs over when needed?
Question #2: If I have a Positive and Negative Bus to which I would connect the MPPT PV inputs AND the LV2424 PV inputs can both the LV2424 and an MPPT be active at the same time or will it fry something? (There is a 100Amp breaker on each solar positive cable which can be easily flipped manually). I keep reading that the MPPT controls the PV and two cooks in one kitchen doesnt sound like it would work....then again, this is not what I do.
Question #3: On a sunny Florida day I see nearly 60 volts from a single side (3x100Watt solar panels in series) but of course the Amps are less than 6Amps. Would a 100/40 MPPT handle this?
Thanks for the inputs Guys/Gals, I don't do this for a living so the documentation isnt make it clear enough for me.
Cheers!
Swampy
Cheers!
Swampy
