I'm getting ready to switch my electric boat from SLA to Lithium. The system is 48V and the SLA had 100AH. But as we all know with SLA you only use 50% capacity. This got me thinking since Lithium can go to 80% do I still need 100AH or can I save a lot by going with 50AH? I also have 440W of solar that is feeding/charging these batteries when the sun is up.
Here's my math - does it look right:
SLA - 4800 watts - usable 2400W, motor normally draws 10.5Amps = 4.76 hrs of run time
Lithium 100ah - 4800 watts but at 80% = 3840W usable, drawing 10.5amps = 7.62 hrs of run time
Lithium 50ah - 2400 watts = 1920W = 3.81 hrs of run time
Obviously, if my math is right I can see the 50ah I would be about an hour less than I was on perfect SLA's, but with the solar doing its job does it matter?
Thank you for your thoughts.
