I'm getting an outbuilding with a south facing single slope roof and would like to put a solar system on it for backup power. I would like it to have grid power pass through ability but would like to avoid dealing with the power company so am avoiding grid tied inverters this is just for a couple circuits not to power my entire home. My maximum load should be about 8kw. Here's what I'm looking at.
6.88kw solar from 16 qcells 430 watt panels open circuit voltage 49.3 and current 10.3a (4x in series x2 in parallel per mppt)
12kw 120/240 split phase sigineer inverter/solar charger with 2x 60a mppt max pv open circuit voltage 250
www.sigineer.com
4x 48v 100ah LiFePO4 sigineer batteries
www.sigineer.com
My concerns are the inverter efficiency isn't that great (peak 85%) the idle load is high at 180 watts and the harmonic distortion seems high. "THD of 7% (min 3%, max 10% under full linear loads) depending on the load connected and battery voltage." I plan on setting the inverter to swap to grid power at 50% state of charge to make the batteries last longer so that should help with the harmonic distortion as well.
I like that the ac input and output are designed to be completely separate since I have no intention to grid sell and if the power company ever asks questions that might help my case. Solar production will be double in the summer so my mini split should be able to compensate for the heat from the idle draw, and in the winter the building needs to be heated anyway. This inverter is low frequency, sigineer has 3kw high frequency inverters with better efficiency (90%) that can be paralleled and synchronized for split phase production but my understanding is low frequency inverters last longer and have better surge capability (300% for 5 seconds) so I'm not sure what the better option is. It might be nice to have the redundancy of 4 inverters if one of them dies as long as it doesn't take out the others in the process.
Thanks for your input.
![www.sigineer.com](http://sigineer.com/wp-content/uploads/2022/06/M12048DUL-800-980-5-v2.jpg)
Solar Power Inverter For Home 12000 Watt 48V to 120V 240V w/ 120A MPPT Controller ETL Listed
12000 Watt Solar Power Inverter For Home |120A solar charger Pure Sine Wave 48V dc to ac 12KW 120/240Vac, off grid, emergency backup power
![www.sigineer.com](https://sigineer.com/wp-content/uploads/2020/12/cropped-SG-Site-Icon-512-32x32.jpg)
![www.sigineer.com](http://sigineer.com/wp-content/uploads/2021/10/LFP48100-800-980-4.jpg)
Powerwall 48V 100AH 8S Li-ion Battery Pack for Energy Storage System
Model #: LFP48100 In stock in California. Free shipping to continental US only . Buy 4 pcs at a time, and get 800USD off.
