Watts Happening
I call it like I see it.
- May 3, 2022
- 802
I understand the business model, I merely meant that you've said it's an amazing product and I don't want to be the cause of people no longer purchasing it. Of course you'll move other products, I totally get it.I tried to read the thread but this thing is massive. Can you summarize the actual problems that you have in the evidence of those problems and all of the error codes with the 18K? I just learned about the Net Zero issue 4 days ago and it seems like the new firmware has it resolved. But I have not tested this feature yet.
And I don't think you understand my business model. If the 18K fails then I will sell more sol arks. I still haven't even added the 18K to my site because I've been busy with other things. I'm here to review and criticize every product on the market.
Let me try to reenact what problems you had. I also need the exact error code so I can try to reproduce it myself.
There has never once been an error code.
Regardless of which person at SS or Gilbert sets it up, it does not peak shave reliably, as a general rule it will pull 150-300w from the battery bank the entire time from 3-9pm that it was programmed to only use batteries. It will then backfeed the grid at random times. It also doesn't follow times in the way you'd expect a computer to, IE "at 3pm" switch to batteries. In Gilberts own words, "it's not perfect and is + or - 8 minutes". Which doesn't sound like much, and agreed isn't much, but it doesn't stop there. I'm seeing it happen hours later.
It also decides to pull from batteries as it wants, IE it's supposed to do 3-9pm but at 10am I see it drawing near 100% from batteries.
It does not have a remote rapid shutdown solution as indicated in the manual, I have asked repeatedly to no avail.
Marcus claims I'm asking for something that doesn't exist, peak shaving from 3-9pm then charge batteries at 10pm. The Sol-Ark does this out of the box.
