Slowly but surely making progress. I received my 100a 48v to 12v Converter, 4 days early from China! This thing feels like its solid lead, its so heavy and feels very well built. I did a quick model of it on the right side for mounting purposes, as all the RV's factory 12v wiring is on the left side there. You can also see the drop floor I'm making (6.5" Lower than factory), and how the 2 inverters will sit, with the PV disconnects mounted to the face of them, and then the Class T Fuse holder and the Bus bars in the center. The small box on the lower left hand corner was the factory box that the generator wires went through, to go to the transfer switch, so I will wire the inverters through the existing wires in there, and both inverters will power the transfer switch like the generator would have, with Inverters having priority over the Grid power. Then if the inverters shut off, grid power will switch on. I hope it all works out!
P.S. Does 13kW of Inverter power put me towards the top of the list for most powerful trailer? Everybody I tell thinks I'm absolutely insane for putting that much inverter power in there.
