Too much solar!
OffgridMatty
I know enough to be dangerous!
Edwards, NY
I have a very small system in upstate NY that currently consists of three 375W solar panels (have a fourth but don't really need it), two 24v EG4 Lifepower batteries in parallel and a Growatt 24v 3000w inverter all in one. My cabin is off grid and is used on weekends year-round and occasionally for a week at a time in the summer. Winter was a challenge at times due to the limited sun and the fact that the system was off while I was away and freezing temperatures and charging LiFepo4 batteries doesn't mix. I still never ran out of usable battery power as I don't have running water in the winter months. I am now in the spring and summer months and my batteries are almost always within 75% to 100% charged. I have no option to share access power to a grid so it just seems like a waste. I really want to know what best practice is for battery longevity. I have thought about turning the PV off and letting the batteries discharge more while I'm at the cabin. Should I be concerned about keeping the high SOC for most of the summer. I needed the two batteries mostly to handle to well pump and small refrigerator start up. I'd love thoughts about what if anything I should do differently. Thanks!
Reactions: Tym
Voltage level + temperature is what degrades all types of Li batteries. Don't have your LFP sit at >3.4V/cell all the time and at >25 deg. C. Run small air conditioner with excess solar to keep battery room cool when away. There is not much else to do with such small amount of excess solar, i would not bother.
Probably best to do nothing different than you do now.
If it’s practical when not needed for months, leave at a reduced state of charge, 50% versus floating at 100%.
If you don’t leave alone for months or it’s not practical, just do nothing different. IMO, constant air conditioning when away is not worth it.
The cabin actually stays pretty cool through the summer months without AC. I may just turn the PV off at times to let the batteries cycle down a bit while I'm there and fill up again in my absence.
Are you running a fridge? What about a water bubbler? Nice small loads will keep the batteries in usable state.
What are your SCC settings? Bulk for 27.6-28v?
Yes I have the fridge running as my only load when away. I'll check the SCC settings. I have never adjusted anything except the battery type.
