The delta is only 41 mv.
Personally I would put them in series and see how they hold together during a cycle to your target cutoff voltage.
If it was me I would discharge them to 3.0 volts at ~0.2c and see what the delta is at the bottom.
Then charge them up to 3.65 volts per cell at ~0.2c and record that delta at the top as well.
If the low delta is acceptable and the high delta is acceptable and the capacity is acceptable then the cells are ready for service.
What BMS are you using?
it’s actually only 31mV (3.589 to 6.200) which I agree is pretty good (up that far into the knee).
But I doubt settling is ‘done’ with voltages close to 3.6V and in my experience, settling will continue to at least 3.5V if not lower.
Once cells have settled in parallel to a voltage close to 3.5V, the major transients are done and if the cells continue to hold voltages close to that level once disconnected, they are top-balanced.
How well bottom-balanced the cells are is largely immaterial.
The real test to know how well-balanced your pack is (and what effective capacity it will deliver you) is to:
1/ Connect top-balanced cells into an 8S battery.
2/ Discharge to your desired cut-off voltage (monitoring cells on the way if you don’t have a BMS).
3a/ if you reach your desired cut-off voltage and no cells have reached LVD of 2.1V (or whatever voltage your BMS will use to protect cells), great - this is the capacity your battery will deliver.
3b/ if one of your cells reaches LVD before battery has reached desired cut-off, that weak cell will determine usable battery capacity (and you will never reach your desired cut-off voltage).
4/ In either case, now charge to full pack is series using an 8S charger (or voltage source set to desired charge voltage), monitoring cells on the way in case you have no BMS.
5a/ If battery voltage reaches target (of ~28v or whatever) without any cells reaching HVD (of 3.65V or whatever), congrats - this should mean that all your cells should have reached ~3.55V around the same time and your battery is perfectly too-balanced.
5b/ one cell hits HVD of 3.65V before battery has reached fully-charged voltage of ~28V, top-balance for your pack leaves room for improvement.
Note that this test is much safer with BMS connected. If you proceed without BMS, cells need to be monitored very closely to assure no cell is discharged below LVD or charged above HVD (which means it is much safer to proceed at lower current levels, especially when any cell voltages are above the upper knee or below the lower knee).
