BarracudaBob
Harvesting free photons from clean fusion
by coiling the wire you increase the inductance their for the more inductance you add the more the voltage will lead the current causing a power factor less than one. The inducive reactance increases with frequency.
XL = 2πfL
The inductive reactance is found directly from the expression XL = 2πfL. Once XL has been found at each frequency, Ohm's law as stated in the equation I = V/XL can be used to find the current at each frequency.
So a couple of nots isn't going to do it. Many turns on a toroid would start to offer some resistance. You still need to give it a place to go. Many surge/RFI arrestors use a combination of capacitors, inductors, and MOV to do the job.
XL = 2πfL
