Rednecktek
Solar Wizard
FTFY!i can tell you the LVX6048WP can charge the battery with inverters off as long as the breaker isopenCLOSED for solar. Although I wouldn't recommend the unit for other reasons.
As a quick aside, mostly because I was curious, we had some sun yesterday so I whipped out my solar dolly and threw a panel on it. The inverter was switched off and my amp clamp meter still showed about 3a going into the battery. The only load on the battery was my Aili shunt showing the battery was charging.
So yes, at least the MPP 1012 does charge from solar with the inverter off.
