nosys70
- Jan 15, 2020
- 839
as usual you need to count your battery as load either, because a battery does not fill by itself.
so he did not say how many watts he got available, but he will need to count the battery as a load, split over the time the source (PV ?) are on (7 hours?) minus the time the battery is discharging.
so a 100A 12v batt is 1200W, to be added to the 1500W load, so 2700W load at worst. (if batt is empty and you charge it in one hour)
Since he said the batt will supply power for only 15 min (the batt has 1200w, and 15min of 1500Wh about 400W, this requires only about 30% of battery capacity to restore).
so really we can count the battery as a 500W load, it decrease the total bill to 2000W.
if you split the 500W over 7 hours, it is only 80Wh to add to the 1500Wh, so about 1600Wh.
But if by any chance you empty the battery drastically more than the 30% requested, you could end up with a battery that will never be able to fully charge on one day.
in that case the best would be to put a 300W solar panel just for charging the batt, and leave the other source for the 1500w load.
