Thank you all for this forum; what a blessing. My main concerns are as follows as I have this charger and trolling motor yet have not purchased the batteries needed (I will be starting out at 24V then possibly switching to 36V if needed as this brushless motor allows):
1) Will this charger, which somehow attempts to try and try again to 'wake up' uncooperative BMS issues, *not play nice* with LiP04 batteries using their own 'way' of solving issues such as low temperature? Under 32F will be my main concern yet I am right on the edge of this ever becoming an issue and wonder if external RV tank heatersheaters such as these would work inside the battery box instead of built in battery heaters.
2) Even though this is a 15A charger, I will be lucky to get that full amperage out of the household circuit used (this unit has low voltage compensation which I 'hope' helps here). Am I stuck with (2) or (someday) (3) 100ah capacity batteries in series versus the higher ah capacity models? How much trolling motor specific benefit is actually gained as you step up in ah rating by 100 ah(s) at a time? I have a Sterling 60Ah charger as well https://cdn.shopify.com/s/files/1/0658/7343/files/PCU_Handbook_2021_rewrite_New.pdf?v=1641915982
yet I don't have two power sources at the dock and am already am trying to figure out how to integrate another (3) bank MinnKota charger for the other batteries on board (yeah, I need more power, period). board-digital-chargers
3) I am probably going go with either the 12V Chins, SOKs or Battle Borns as recommended here. Chins seems to be at least 'somewhat' marine grade in all models (they claim IP65) . SOK only has that one 200ah model and Battle Born enclosures are apparently not an issue. Am I somewhere in the ballpark in terms of selecting the best near or budget grade half way decent quality grade out there right now?
Again, thank you so much for this forum and definitely the YouTube channel. I'll tackle solar next and am so glad that I didn't years ago with the prices where they are at now (I'm old and these paybacks now are frankly unbelievable).![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Latest model Minkota Model MK460 PCL 4 bank charger overview/specs:
MK460PCL manual: https://minnkotamotors.johnsonoutdo...202.154594191.1645315817-327411339.1644851392
