In my region (in Sweden) the winter months are quite dark, there is some sunlight, sun goes up at around 9am and goes down at around 3pm. I used a calculator which said I can produce 3600kWh a year in my region using solar panels. Just for my understanding, can I not "get" more solar power from the sun that is shining the more panels I install? There is a difference between having 2 panels or 20 when the sun is out, isnt it? So cant I not for example produce 7200kWh a year by just having more panels and of course the matching equipment like the MPPT and batteries?
I'm not sure if I'm going to invest in solar, or have power put in. Is it even possible to run soley on solar power in regions like mine? Would you recommend having a generator as backup?
Thanks
Thanks
