I checked the other posts on isolator topics and none seem to address my question. So here's some background on my situation: I recently upgraded my 900ah AGM battery bank to an 800ah Lifepo4 battery bank. Rather than stick my nearly new AGM's in a corner and forget about them I've wired them back into my system as back up storage. Ive got them connected via a high amp 5 post solenoid that engages the AGMs as it disengages the lithium's and vise versa. I can activate this solenoid switch from within my RV. The only problem is that the bank of AGM's is not currently connected to any of my Solar arrays for charging purposes.
I had been thinking about using a manual transfer switch to connect the output of at least one of my three solar charge controllers to both battery banks but getting out of my RV to flip the switch when the AGM's needed a charge and having to remember to flip it back later seemed like it would be a challenge for me. Then, while researching/shopping for a better solution, I stumbled across the Victron battery isolators. From what Ive learned about them, one would connect both battery banks to a common ground, a charging source is connected to the input, one battery bank to output #1 and one battery bank to output #2. The isolator keeps both battery banks completely separate from each other yet allows both to be charged by the same charging source. Directing a charge into two different banks of batteries while keeping those batteries separated is all the isolator does. Whatever comes into it from a charging source is what it provides to the batteries connected to it.
I dont think that these isolators were originally designed to be connected to a battery bank of lithiums and a battery bank of AGM's but Im trying to figure out if/how doing so would be harmful to either bank of batteries. Using my admittedly limited knowledge of all of this stuff, it seems to me that since lithium batteries have a lower internal resistance than AGM's, the lithiums would draw most of the current at first and charge up. Once they were full, the AGM's would then start charging. If this is indeed how it would work, its exactly what I would want.
The only thing that the AGM batteries will be connected to full time is a very low draw, wireless temp monitoring system that monitors the temp in my lithium battery compartment. Other than that, the AGM's will be used as back up storage, only to be employed during overly long stretches of cloudy days. This is why I feel that I can keep the AGM bank topped off secondary to the lithium battery bank and using just one of my solar arrays/controllers. I can always add the input of a second solar array/controller to the isolator later if keeping the AGM's topped off requires it(60amp controllers, 200amp isolator).
Currently, my charge controllers are set for "lithium" batteries and at 14.4v charging. For the one controller connected to the isolator, I'd keep that same 14.4v max setting but set the controller to AGM and program a float charge of 13.8v. From what Ive read, such settings should work well enough for both battery types since the Lithium batteries would effectively ignore the float charge anyway.
So does anyone know for sure if this will work? Or not work? And why? Any info or insight about the idea would be extremely appreciated. Thanks!
PS: If this isolator option isn't feasible, Ill probably hook the charge controller(s) up to both battery banks via another $15 high amp, 5 post relay with a switch to activate the relay installed an instrument panel up inside my RV. The panel is already there and houses the gauges and so on that I use to monitor my solar power set up. This would work fine but would mean that Id have to remember to switch back and forth and Ive always been a bit scatterbrained. Having the charging happen automatically would be a huge plus for me.
