Brucey
Solar Wizard
Does she have a sister?My wife asked for a shunt for the power cart.
More blue stuff came in.
Only child.Does she have a sister?
I am tempted by the new Midnite inverters. I wonder if Midnite would do custom colors ???You have a sickness sir. You need to have this looked into.
You could prob take the aluminium case and get it plasti dipped in Victron blueOnly child.
"Spray painted RAL 5012"You could prob take the aluminium case and get itplasti dippedin Victron blue
Soon....I'm going Blue one step at a time
Smart 100/50 & 150/70 connected to a Power-In
Yes that's just sitting there temporarily it will all eventually be wall mounted. Good point on getting boots.You do realize the little caps that come with new batteries are just decorative and a fire hazard verse meant to be used aas an insulator?
And I would for sure put an unsulator betweent the back of the breaker and the battery. Or the cable boots on them before putting the lynx lid on.
I actually put cable boots on every cable I make, I figure whatever it is connected to should be insulated.
Yes just saw those the other day. Perfect to transition from chunky pv wire to windynation power flex cable or similar.Finalizing the last bits of how everything is going to be done and I think I've settled on this guy: https://www.currentconnected.com/product/midnite-solar-mntransition-box/
Bring the output from the PV disconnects into these which will facilitate connecting my SPD's for each string. It seems like, I remember seeing the Victron RS450/100 they want finer stranded wire coming into and out of it than the regular PV wire. Or am I imagining that?
