I recently put together a solaredge system with 27x solarever 455w panels with Enphase IQ8A inverters. Prior to PTO and the installation of a production meter by my utility I ran some tests and production curves appeared as you would expect. The only change was the addition of the meter instead of the metal bars I was using for testing. This meter is after the combiner box but before the main panel.
Following PTO my production got wonky and suddenly seems to kick in suddenly at 10am
What would cause this weird production? The panels are in full sun and the utility production meter along with the Envoy solar production monitor show virtually 0 Production.i thought maybe it was just a reporting issue but seems to be actual production.
I get a blip of production in the morning and then it ceases until 10 and then flows a normal production path the rest of the day.
I’ve attached some photos here the top two are pre PTO and the bottom is post PTO.
Any ideas?
Any ideas?
