Amy's Bulk cells are those which do not meet the overall performance specs for Grade-A during the Matching & Batching process, but are new production batch, not Old Stock nor from Battery Brokers (grey market).
I have both types in my packs.
Matched will perform through the operating voltage very closely, all cells vary a little during operation. They will generally be able to handle full capacity as designated, so a 280AH Pack built with Matched Cells have 280AH Capacity within it's "Working Voltage Range" of 2.900-3.450Vpc and most often can be "pushed" to 290AH from 2.500-3.650Vpc Max Voltage Limits.
Bulk cell Packs are "dominated" by Runner Cells. These are either weaker or stronger, usually a different internal resistance. They can either take charge faster than the other cells, therefore running to Hi Volt Cutoff @ 3.650Vpc OR then could discharge faster than the others, reaching Lo Volt Cutoff @ 2.500Vpc leaving the other cells in a higher state of charge. See Special Note. This can mean that the Full Working Voltage Range is reduced to the Lowest Denominator and as the efficiency over time decreases for any single cell, it will bring down the rest. While you may build a pack with 280AH Cells, a Runner or two could very easily limit it to 270 or even 260AH...
Special Note: Active or Passive Balancers CANNOT Fix this ! An Active Balancer can minimize "take the edge off" but only in a limited way, that is not their purpose or design. Passive Balancing is of little use on Large Cells above 100AH and only actually makes a difference when used with perfect Matched, Batched & Binned cells which are identical.
Please download the Lyuan Tech LifePo guide & Voltage chart from my Signature, they'll help you a lot and explain several things.
Hope it helps, Good Luck.
Steve
