I just can't imagine a mini fridge that's NOT on a continuous cycle would require SO MUCH knowledge to function. Im so confused about all this that Im probably just going to run my Ecoflow Delta 2 with my extra battery and hope for the best. Anybody need any components? ha
I guess this is the central part of your problem. If you don't do the math, you can't understand what you need.
You really don't need to imagine anything. The specifications of everything is available if you put in the time to look for it. So, let's look at a mini-frig. Went to the HomeDepot website, and picked a random model, made by RCA.
Clicked on the Energy Guide, on the right side of pic number two
OK, if this mini-frig consumes 219kWh per year, on average it will consume 219kWh/365days = 0.6kWh, or 600Wh.
The inverter just staying on consumes power itself. How much depends partially on the size of the inverter, and secondly on the quality of design. Let's guesstimate you get one that consumes ~ 25W continous. The Samlex PST-2000 is in that range. So, 25W X 24 hours per day = 600Wh. Let's say you keep 100W of lights on for four hours, that's 400Wh. Finally, maybe two hours of computer or TV time, maybe 50W for 2 hours = 100Wh.
Add that all up and you get 600Wh + 600Wh + 400Wh +100Wh = 1700Wh per day. That's a realistic number that I've actually seen myself with my own system. Let's say though you go with a range, and say you need between 1500Wh and 2500Wh per day. Call it an average of 2000Wh, or 2kWh.
This is an example of what people are talking about when they say "you need to do your homework". If you are located in South Carolina, at about 35 degees North, I'd guesstimate you get 3.0sunhours of light in winter and 6.0sunhours in summer. In December, a system with 530W of panels might make 530W X 3.0sh = 1590Wh of power. Maybe, just barely enough that you might break even. Maybe, barely, assuming you have clear, sunny weather. At your location, what's the likelyhood that if the power goes off in December, the weather will be clear and sunny?
Having more watts of solar means that in less than ideal conditions, you will make the amount of power you need. Here is a plan that will let your system grow if you find you've made mistakes in your calculations. Mistakes though that are fixable.
Buy a high-voltage charge controller like the Epever 6415 or 6420, and the 24V sine-wave inverter. Wire your batteries for 24V. Start out with two 265W panels, that you wire in series to get 62Vmp. Feed that into your 6415 controller that transforms it down to 25-28 charging volts. Operate the the system for a while and see if you can keep the batteries charged without the system crashing.
If it doesn't, then wire another 265W panel in series to get 795W at 93V. If you still don't get enough to successfully power the system, add a fourth panel. You could wire this either 2S2P, or 4S1P with the 6420 controller. Only 2S2P if you got the 6415. If that's still not enough power, go with all six, and wire them 3S2P. That I think will make you a reliable 24V that is not going to let you down. It WILL keep the lights on, even in December.
