redmessengerbag
- Mar 15, 2020
- 41
So I've got the Xuba 280ah cells and all of the components for my camper van, I just need to hook it all up! Here is the schematic I came with using Will's guide with Renogy DC-DC/Solar 50a system, but I've replaced the MPPT/DC-DC with a Kisae Abso DMT1250. The reasons why I chose the Kisae is it accepts 24v solar charging, and it is more programmable than the Renogy.
Kisae is only a one way charger go from input (solar/starter batt) to house only, doesn't go the other way. Kisae's tech support has been incredible and has been very responsive with detailed answers to my questions and suggested a battery switch that can combine the two batteries for emergency starting purposes. So
1. normal operation house battery charged by starter/solar
2. house and starter batteries are combined
3. Off, nothing connected (for maintenance
Just wanted to see if this makes sense.
The one burning questions I have is it appears in Will's diagram that the house battery is on a separate circuit all grounded back to the house battery and not to the chasis. However it seems the Abso Charger the 2 inputs and one 1 output are all bonded together with an isolated/separate chasis ground. Kisae told me that both grounds can go to the same chasis ground, but of course with separate wires. Anyhow, I am trying to figure if there are any issues with this. Thanks!
NOTE: The ground in the last part is something i put on the diagram that is not in will's wiring design and I'm not sure if that is appropriate.
