You are going to run into a lot of technical issues - stay away.So, if the Positive Ground controller is only 1/3 the price why not get it instead?
A PWM controller switches on/off (modulates) the ungrounded connection between the solar panel(s) (+ in a negative ground system and or - in a positive ground system) and the battery. The electronics required for switching on the positive side is a little more complicated (& hence more expensive) that what's needed for switching on the negative line. Since most vehicles have negative ground electrical system, a positive ground controller won't work. A positive ground controller may be used in small, standalone off-grid installation, as in a small cabinSpecifically, what is the difference between these two Renogy 10A charge controllers? They are both identical in appearance, but one is "positive ground".
My comment was referenced to vehicles , RV’s , caravans etc where you are going to integrate into existing electrical systems. Would have been nice if you had all the info up front.You are going to run into a lot of technical issues - stay away.
I agree , the ‘earth‘ or ‘ground’ part should never have entered the conversation. In a ‘positive‘ ground system in a vehicle the battery positive is tied to the chassis.@pierre , tbh I'm of the opinion it doesn't matter for vehicles either. The term "positive ground" or "negative ground" doesn't actually refer to the case of the device, rather which side is switched. It's a rather bad choice of labelling if you ask me. They should have used "high side switching" and "low side switching", which is both the more conventional electronics term, is accurate and specific, and not liable to be confused with other separate concepts.
If you refer the figure I posted earlier, you'll see both examples were for a "negative chassis", e.g. a car/van.
The controller case, bolted to a vehicle chassis, would be isolated from all inputs and outputs. (Not saying there aren't examples out there that have the case connected to one of the inputs and/or outputs, but that'd be a pretty poor design.)
You have to mount it so the case is isolated. The case will be neutral to positive and hot to negative.
So if 'positive ground' / 'low side switching' devices are cheaper to manufacture, and don't effect the design / grounding logic / OCP of the rest of the system, why are almost all controllers 'high side switching'? ...
