What makes the tier 1 stuff “better”?
Nan_wpg
Renogy 45a mppt 200 bucks. Morningstar tristar 45a mppt 588 bucks. Morningstar genstar even more money.
the components are similar and I’m sure the cost to make are similar. (Morningstar has massive heat sinks so there’s that)
China made is cheaper, so maybe is it the USA engineering? Marketing?
just curious.
For stand-alone charge controllers - a key issue is ETL/UL certification and another is features. Besides ETL/UL - Midnites have Arc Fault, DC Ground Fault, full internet (remote control), auxiliary relay, multi-unit synchronization, and several other features and... after being around for many years, they have a reputation for very long life. I would put them in Tier 1.
The Midnite Classic ETL/UL + features are why I was OK with ~$700 for 4200w of PV input / 86a of 48v charging the Classic 150s can provide.
Lots of people use midnite. But I e read on another site that the classics dont put out what they say they do.
The Classic 150 is built like a tank. If you look at the following on the forum there are a number of Tier 1 members. Midnite and Victron got their reputations due to their reliability in the field over the years. There are a number of other products which have done well with the test of time as well.
Can't speak to what you've read, but for the record, I operate 3 of them, for over 4 years now and they work exactly as advertised.
website said he swapped out classics with Morningstar and the difference was significant. He has a bias towards Morningstar, and magnum. Also very anti lithium which doesn’t make sense.
Some people do great with Rentogy. Many don’t. I didn’t go that way when I was looking for lower priced but good value components because everywhere I looked people were posting issues for the brand.
For ~$200 price point (a little bit more actually) I can say the positive use reports for Epever SCCs are valid. Otherwise the victron, morningstar, and outback stuff buys you decent warranties and customer service as well as perhaps longevity.
Well, what guy and what website? Where's the data? Like OGITC, I've used Midnight controllers for years, and they can put out exactly what they say they can. I've sat in my utility room and watched the numbers in real-time. I wouldn't hesitate to recommend them to anyone.
BTW though, I usually suggest Epever because users on this site tend to be penny-pinchers that cann't see past W/$. The suggestions for the high-end, tier-1 products that I myself buy are generally not well-received.
Here's a link to one of RCinFL's technical explainations, which goes into far better technical detail then I could ever hope to give.
Here are his details, cut and pasted. Although this review is concerning inverters, I'm sure that the same general conclusions could be applied to imported charge controllers as well.
Many of the high freq inverters are very low cost, and low quality. There are only a couple of good quality models.
As to U.S. split phase, many of Chinese inverters, either HF or LF are just poor design showing a poor understanding of split phase requirements.
Their designs select parts spec'd with little to no design margin. Battery input line caps have 63v rating for 48v inverter, HV DC filter caps and PV input caps are 500v rating, with max PV input voltage specs on inverter of 500vdc. There are very small value filter caps on HV DC node so there is a lot of 2x AC out freq ripple voltage on them which heats up electrolytic caps reducing their lifespan. It also gives them little to no surge capability. PV input caps are very low in capacitance so there will often be ripple getting through to PV panel loading which reduces panel maximum power point output current. AC connect relays are cheap water heater relays rated for resistive loads. On higher wattage inverter models they put two of these cheap 40A resistive load rated relays in parallel to handle higher AC current.
High no-load idle current is mostly the result of poor design, lacking the knowledge of how to minimize switching losses, and/or allowing more switching crossover tolerance slop to allow for random part substitutions in manufacturing.
HF split phase have two individual inverter circuits operating in series similar to 240/120 vac inverter-generators. Although could be a single inverter circuit, most HF inverters use an H-bridge PWM chopping sinewave generating output stage. This means their high voltage DC supply must be independent between the the two split phases with two separate PWM output stages.
Most of the Chinese HF all-in-one inverters do not have their PV inputs isolated from AC output. This means the PV panels wiring are riding on top of the inverter PWM high voltage DC polarity switching from the PWM AC output H-bridge. You must use double pole DC breakers to PV panels to disconnect both positive and negative lines to PV panels.
True bi-directional battery to HV DC converters are difficult to design and control. Many Chinese HF inverters do not attempt to do it. They just put a parallel buck converter circuit change-over to charge battery from HV DC node. This takes some switchover time which limits the functionality of many HF hybrid inverters. For example, they cannot do load shaving or load supplimenting by inverter with grid or generator AC input. When connected to AC input they only allow AC pass-through and battery charging from AC input. They cannot suppliment a generator with limited power output.
Many of the recent low freq inverters from China do not have the management/control of split phase grid neutral voltage imbalance and cannot be connected to grid neutral in a code complient install. They don't provide for split phase AC input grid neutral connection making them non-code complient.
With single center tapped output transformer low frequency inverters, there must be grid neutral management to prevent output transformer from trying to correct for grid L1-N to L2-N voltage imbalance that can cause high currents in output transformer. Lacking the safe guard to check for this, the low cost LF inverters cannot safely be connected to grid neutral.
Be careful of HF inverter surge claims. 2x surge capability for a couple of msecs is no surge capability. Single phase induction motors startup surge is 400 to 500 msecs long so any surge spec less than at least a half a second is pretty much useless.
Also be careful of believing specs. With All-in-One inverters there are many ways to stretch the true. For example a HF all-in-one inverter specs, "DC to AC conversion efficiency = 96%" and is only efficiency spec listed. Intent is to make you believe this is inverter battery to AC output efficiency. It is not.
It is PV DC input, when PV voltage is close to inverter's internal HV DC node so PV SCC boost is barely required to boost PV voltage up to HV DC node so its efficiency is very high, like 99%. Most of the 96% efficiency number is just the high voltage DC to sinewave PWM H-bridge switching loss and L-C output filter loss.
Battery to HV DC boost converter, which is about 94% efficient by itself, is not involved in this path. Optimum battery to AC out efficiency is about 93% which is about the same as LF inverters.
One manufacture finds a way to stretch the truth and all other manufacturers follow in order to be competitive. Most of the Chinese HF all-in-one inverters are just copies of the same basic circuit with individual manufacturer's effort put into pulling a few more pennies of cost out of bill of material. Build lot, to build lot, of a given inverter model will have different parts depending on what parts are available at the lowest cost.
Typo. Renogy has a 40a. It’s in the ballpark
Renogy is limited to 24V battery, so half the power ability to the MorningStar with is 12-48V
MorningStar Tristar ( 60 amp ) is has 3 buck converters 120 degrees out of phase which makes is more efficient at high power levels, the 45A is the exact same unit with 2 buck converters for some cost savings ( I was on the development team for that product )
In General, tier one means is time proven with good support, likely has conformal coating on the circuit boards and no fans for long term reliability.
3 buck is dollars, or a term in the industry?
you work for Morningstar?
I have a suresine inverter. It’s built like a tank. Guy on our lake swears by the controllers, and says their new inverters are tanks.
Google “Handybob solar”. He’s got a lot of info on solar.
i,honeslty don’t understand much of all that, but it does sound like I should avoid the China AIO units.
"Buck" converter is the technical term for the typology of the power converter used in charge controller. Most stand alone mppt charge controllers are this type. AIO could be buck or boost for the mppt.
The Tristar Mppt was Developed 2008-2010 and I did work for Morningstar then.
I would consider it a courtesy to actually cut and paste a link.
that’s the page on the classic. He’s got a bunch of other stuff. I,used,his info years ago when I first got into solar.
That guy had some real issues with the classic and with Midnite. Others seem pleased.
When Handy Bob Solar said 4 awg doesn't fit well, he lost me. #4 fits fine. Makes me doubt everything else he says, when something simple like that gets called out as a problem for him.
Also, it does include a manual now.
I've never heard the fans on mine, but I'm running it at low power, so not likely to need cooling.
When Handy Bon Solar said 4 awg doesn't fit well, he lost me. #4 fits fine. Makes me doubt everything else he says, when something simple like that gets called out as a problem for him.
Would you be able to fit #2? you havent had any of the issues he did?
it’s possible they had a bad production run, or they’ve improved.
I don't have any #2 handy, but they are listed for #4, so I doubt #2 would fit.
I've had 0 issues. I'm running lithium batteries, so equalization, which he really got worked up about, doesn't apply to me.
The 4awg welding cable (100s of small strands) do take a steady hand to fit into 4awg sockets but it worked OK for me. One can also use ferrules to help make it go easier.
Arc Fault went off on 2 of 3 of my Classics with default settings - but a small sensitivity tweak of 11 to 12 or maybe 10 to 12 smoothed it out. I'm glad to have this feature. It can also be disabled if you don't want the feature or to bother learning about it.
Fans - yes there are fans and there are fan kits and they make some noise - no doubt.
Equalize - I'm lithium-ion and don't use but all the other settings work exactly as advertised.
Efficiency - as advertised as far as I can tell. I know my overall loss and assuming the Midnites are 2% then the other losses are easily accounted for. I don't see the Classics as standing out as a problem in the overall efficiency so I believe their specs.
After 4.5 years of continuous operation and 68,551kwh PV incoming (~22,850kwh per Classic 150) no problems or failures to date.
Support - See this thread I did recently as a shout-out to *fantastic* support - https://diysolarforum.com/threads/shout-out-to-excellent-midnite-tech-support.49111/
Are Classics perfect? - no, but is anything perfect? So far, these have been the most reliable part of my off-grid system and I'd defend them as a Tier 1 level of equipment / recommend them for component based off-grid design.
If you've got questions for Midnite, they are a member here. You could shoot up the bat symbol (put an @ in front of "SpongeboB SineWave"), if you've got any direct questions, he'll probably answer them.
I called Midnite support for a possibility unrelated issue. They happily worked through their side with me and we verified everything on their charge controller was great. The entire call lasted less than 5 minutes, I don't even think I was put on hold or into a queue.
ive Read lots about midnige support. All of it good. (Except for Handybob). Couple cabins on my lake have MidNite gear. No issues.
support definately is of value and a part of “top tier”
*price, quality, service…. Pick 2. Grandfather always blurted that out to me.
