Where are you able to buy Mitsubishi for a self install?@Supervstech i was looking at a pioneer 24k but rethinking based on your response . The Mitsubishi 24k for same seer(20.5) is $1k more. Are they actually that much better?
Budget Heating and Air in Houston is one.Where are you able to buy Mitsubishi for a self install?
Nice.Budget Heating and Air in Houston is one.
Here's a link to the 24k BTU 20.5 SEER @$2,725.
Mini Split 24,000 BTU Mitsubishi 20.5 SEER Heat Pump System MUZGL24NAU1, MSZGL24NAU1
Enjoy the comforts of Mitsubishi, the leader in heat pump mini splits. The MUZ/MSZ line offers superior efficiency up to 23.2 SEER. DC inverter-driven & ductless installation are just a couple of the benefits backed with the best warranty in the business.www.budgetheating.com
I'm pretty sure he does. He's like an HVAC guru.Nice.
I hope supervstech knows there is no warranty with self install?
How's the mini split doing? And the inverters?I will keep this thread updated with results after a couple days.
Nice.
Sorry I meant chrisgI'm pretty sure he does. He's like an HVAC guru.
Haven’t bought anything yet. Still researching. Fully the understand they warranty issue with self install.Where are you able to buy Mitsubishi for a self install?
Ah. That makes sense now.Sorry I meant chrisg
Got mine through eComfort dot com. Came either UPS or a short box truck from an independent carrier right up my driveway. Usually I have to meet trucks out on the county road and off load them with my tractor and forks.Where are you able to buy Mitsubishi for a self install?
I know someone who has a Mr cool. Doesn't maintain set point. You set it to 70 degrees and it will just keep cooling till well below that. I wouldn't buy oneI think with mr cool being aimed at diy I imagine there are the only ones to choose from if you want a warranty and are self installing.
This from mr cool's site :
*State certified or licensed HVAC contractor not required for warranty on
the DIY series units. (Always check your local laws.)
Well technically every mini split I have does that. What you set it to and what the room is are rarely related.I know someone who has a Mr cool. Doesn't maintain set point. You set it to 70 degrees and it will just keep cooling till well below that. I wouldn't buy one
Ok that might be true I don't know. My mini splits are ducted and can either use the temperature sensor in the air handler or the one in the thermostat. They maintain temperature pretty wellWell technically every mini split I have does that. What you set it to and what the room is are rarely related.
The wall temperature throws them off depending on how warm the wall gets.
The only unit I have that is dead accurate are the ones with remote thermostats like a traditional hvac home system or the roll around unit I have which the remote is the units actual thermometer.
The traditional mini split ductless ones I have seen have a sensor in the air handler on the wall and that's it. I've got more than 9 of them and I have to tinker with the temp settings depending on time of day. My office for example which falls into the extreme category with no insulation (its an poorly enclosed porchOk that might be true I don't know. My mini splits are ducted and can either use the temperature sensor in the air handler or the one in the thermostat. They maintain temperature pretty well
Ok yours seen to be working well. The Mr cool I know of works more like off/on. It will keep cooling until you turn it off.The traditional mini split ductless ones I have seen have a sensor in the air handler on the wall and that's it. I've got more than 9 of them and I have to tinker with the temp settings depending on time of day. My office for example which falls into the extreme category with no insulation (its an poorly enclosed porch) ranges from 70 to 75 with the unit set at 77. Coolest part of the night will be around 75 and during the day it sits around 70.
Now bricked part of the house with good insulation I keep set around 74 and they range from 72 to 74 depending on the time of day.
The ones with sensors in the remotes and the roll around which has the sensor in the remote are pretty accurate within 2 to 4 degree variance from whatever you set them to no matter the time of day.
Not yet. I have ramsond brand for my mini splits and DeLonghi Portable Air Conditioner 14,000 BTU as the roll around.Ok yours seen to be working well. The Mr cool I know of works more like off/on. It will keep cooling until you turn it off.
Do you have any Mr. Cools?
Funny I actually just got on the forum to come to this thread and update. My buddy finally got the time to come over and help me run the wiring from the panel to the AC Disconnect and to the outdoor unit. Got it up and running and it is on and maintaining 80* right now.How's the mini split doing? And the inverters?
I will add this Della unit does have the option to use the temp sensor in the remote. I set it over on the other side of the room near the inverters, but not in path of where heat from the inverter would affect it.The only unit I have that is dead accurate are the ones with remote thermostats like a traditional hvac home system or the roll around unit I have which the remote is the units actual thermometer.
Find a local independent HVAC man, get him to sign off for $50, a remote visit inspection via your phone.....easiest $50 he ever made.So it seems everything other than MrCool DIY loses warranty if self installed. Because of the location fees to get out to my cabin for service, I’d rather DIY but buy a well built unit(s).
So, Mitsubishi seems to get top honors if I can get my hands on one and install kit. Daikin seems to be in second place, Della third and others are a mix below that. Need low ambient heating and obviously low power consumption inverter style. Time to rethink this.
Ha $50 would be awesome. The local travel expense for any visit is $200 each time and unsure if licensed.Find a local independent HVAC man, get him to sign off for $50, a remote visit inspection via your phone.....easiest $50 he ever made.
You're overthinking thisSo it seems everything other than MrCool DIY loses warranty if self installed. Because of the location fees to get out to my cabin for service, I’d rather DIY but buy a well built unit(s).
I said find a guy who wants to make $50 by inspecting your work over the phone.....all you need is his license number and sign off on the install.Ha $50 would be awesome. The local travel expense for any visit is $200 each time and unsure if licensed.
New entrant in pricey Mr Cool DIY category, DEYE / EG4 / SS ...though SS and "warranty fulfillment " are terms that appear daunting to be used together. Just putting info out here. Couldn't go wrong with Mitsubishi warranty or no IMHO.So it seems everything other than MrCool DIY loses warranty if self installed.
If I had it to do over I might go this route on the garage. I love the Mitsubishi but they aren't cheap. Definitely something to consider, especially for the area where the batteries live. Are you looking at 48v units for other areas of the house? I'm wondering what the wiring for those would look like. I don't have any place that doesn't already have a new unit but I'm just curious. Would you set up a separate breaker panel with DC breakers for those units?Late to the party.
I chose the Hotspot 48vdc 12k btu.
It made the most sense for me. Because I already have a system and batteries. I didn't need to increase any part of my system to accommodate the mini split. Just connect it to the battery bank and go.
I will be installing more of the same units, later in the build.
