davecason
Hi,
I have a set of four standard LiFePO4 cells from Basen in China I used them on a road trip to power a fridge however since I got back they seem to be acting weird. (I know, very highly technical, right?) Yes, total newbie here .... hence, I'm in the right forum topic anyway .......
The stickers on them say:
3.2V LiFePo4 Cell
Capacity: 272 Ah
Voltage: 3.24 V
IR: 0.12 mOHM
Shenzhen Basen Technology Co., Ltd
Address, etc ......
My problem is I think my DALY controller is "unhappy" so I'd like to test / check each cell with my limited resources right now, so me buying a new controller is out till get one of those job thingy's ...... Can one of you folks confirm this suggestion below?
I was told that I can put my Nice Power bench supply on each cell at 3.65 v and 300 mh to see if they are OK. I did one cell for a couple of hours and it has come up, so it does take a charge but what should I be seeing with either the DVM meter or the display on the bench supply?
I set the supply up for 3.65 vdc out and .300 amps and let it run ...... but as for how valid this is as a suggestion and how long I should have the supply hooked up to a single cell, I have no clue. If you have any suggestions or some reading I can do to learn how to do it properly do it, it wild be much appreciated.
Cheers'
Dave
3.2V LiFePo4 Cell
Capacity: 272 Ah
Voltage: 3.24 V
IR: 0.12 mOHM
Address, etc ......
Cheers'
Dave
