Converting a big white pine into firewood. About 48" at the base, it was around 120 feet high. I hired a tree climber to climb it, He dropped the top 50 feet while up in the tree and then dropped the lower 70' in one piece. It cracked in two spots, but I did get two nice base logs and a couple of others a bit higher. Counting rings that tree was around 125 to 130 years old, a youngster by west coast standards but good size for northern NH. I started out trying to split the logs by scoring them with a chain saw and then using hydraulic jacks but that didnt work (dont believe folks on internet forums
) so I sawed the biggest two with a big chainsaw. That took a lot of effort and some waste, so I then hired a guy come to the site to slab the wood into 8" deep slabs log width with a Lucas portable mill. The logs were 10'6" long and estimated weight was 4000 plus pounds each green. Sitting in the background of the Lucas mIll shot is my trusty FLU 419 (Unimog) army surplus backhoe loader that was used to drag the logs around the lot and load the slabs onto trailers. I was right on the edge of its capability. We made two 46" 2" thick slabs, one of which is now someone's bar top. Then (no photos) we hauled the slabs to my friend's bandsaw mill and after sawing the slabs to 28" wide with a chainsaw to fit in the mill, then sawed them into boards. Ended up with two piles of boards 4' wide and about 5' high. There was a bit of ant damage in a few spots but most of the bottom logs were clear and relatively tight grain. Tight grain white pine is not something you see at most lumber dealers as most loggers cut pines when they are half the diameter of this one. They are sticked up and drying. The last stack photo has some aspen boards that I had cut earlier on top of the pine to keep it flat. In the next to last photo there is a 2 foot wide by 2" thick slab I kept just for the heck of it for some future project. WIde slabs can crack and warp as they dry so I usually stick with the smaller stuff. I paint all the ends of the logs with wax penetrant that reduces splitting and also leave the logs a bit long so when I need one I have some end trim.
