Does it cost you additional to tie into the grid?
Yes. My brother's windtower is a prime example. It was done about 10 years ago and NEC code was probably 2008 yet still in this state but the state did increase the State Fire Marshall department to now include inspectors. Requirements of the utility were any electrical interconnection was by a licensed electrician (our cousin was at the time), had to be inspected, he paid for an upgrade to service and the special liability policy which he is still paying for today.
I installed my off grid system myself, I didn't need to upgrade the service or hire a licensed electrician, didn't need any permits and I don't need ongoing costs of a special liability policy.
How much of your energy use does solar offset?
My house is 100% run off grid. The only time I switch to utility is when I need to work on the system which is rare once I installed the LV6548's that replaced the EG4 version. If I didn't have the utility, I could easily use a generator for those short periods.
The property has electrical service to other buildings.
If you are offsetting a large portion in the summer then in the shoulder months, no amount of dump load is going to cover all your generation so you are throwing solar away.
Right now I am using all I'm generating and just get to 100% SOC some days about the time the sun is NW of the array.
But I'm only using half of the array. I could use the shop as a dump load for the other half, the air conditioning in there takes a huge amount of power for some reason.
If you are so obsessed with every Kwh an array can produce, you should go to the direct DC mini split threads where the members install a large array to power a mini split and leave yield potential unharvested...........
So if it doesn't cost you more to be grid tied,
But it does cost more to be grid tied.
that excess solar that would have been thrown away, would be bought by the utility and you would save even more money.
Like I said, I can always divert to other uses. It isn't hard for me to do so.
Bring grid tied does not prevent load management. What it prevents is strobe lights, ac soft starts, worrying about starting your well pump ,lots of money into batteries, etc etc ad nauseam.
My well starts fine, large battery bank and inverters that can run it. No more strobe lights after installing the LV6548's. We live normally other than not running very large draws at the same time such as electric dryer with microwave, washing machine and dishwasher all at the same time.
https://diysolarforum.com/threads/yeee-haaa…-finally-….64836/post-811088
Battery cost is $0.02/Kwh. That's easily recovered compared to the utility getting free Kwh.
