My Fujitsu 9000 btu 33 SEER mini hp pulls 3.7A max at 240V in cool mode and 7.0A in heat. My total kWh per day is around 6.0, but that depends on too many factors. I would recommend getting the highest SEER rated unit that you can afford.Trying to determine the actual 24 hour usage and what 120v system is the most efficient, there are so many different brands out there now I would like to hear first hand experiences. Hopefully someone has used a watt meter to determine. thanks
I completely agree! My 240V Fujitsu 12k MS uses very little for AC (2-3 kw/day?) for my application, but uses a lot more for heating. A friend has the same model and his consumption is at least 2-3 times as much. There's so many variables.There are a lot of variables. Set temp, outside ambient temp, how well the structure is insulated, sun exposure, other heat sources within the structure, etc. The exact same unit may use 2x as much power for one person than another.
I have 2, one is a GREE which pulls pretty well 11 amps or 31680 watts in a 24 hour period. This unit does have a compressor. The second unit is a Prime, this is an inverter unit, no compressor. It also pulls appx 11 amps to start but in a 24 hour period uses appx 14400 watts in a 24 hour period. This is literally running 24 hours per day in this hot 100+ degree temps. Both are 110 units.Trying to determine the actual 24 hour usage and what 120v system is the most efficient, there are so many different brands out there now I would like to hear first hand experiences. Hopefully someone has used a watt meter to determine. thanks
Both units have a compressor. One has a PSC motor, one has an inverter driven 3Ph motor…I have 2, one is a GREE which pulls pretty well 11 amps or 31680 watts in a 24 hour period. This unit does have a compressor. The second unit is a Prime, this is an inverter unit, no compressor. It also pulls appx 11 amps to start but in a 24 hour period uses appx 14400 watts in a 24 hour period. This is literally running 24 hours per day in this hot 100+ degree temps. Both are 110 units.
Thanks for pointing that out. What little I know of A/C and refrigeration is that it is fundamentally a cycle of compression and expansion.Both units have a compressor.
I run a 9000 BTU Senville in my 7 x 14 cargo trailer with 1" (R5) insulation all around (floor, ceiling, walls, nooks/crannies) and no windows.Trying to determine the actual 24 hour usage and what 120v system is the most efficient, there are so many different brands out there now I would like to hear first hand experiences. Hopefully someone has used a watt meter to determine. thanks
So I assume your unit is running full time and not cycling off as its basically pulling on avg 6.6 amps. Thanks for your input, mine will be used to supplement our main ac and will be run off solar. I'm just trying to get some real time numbers knowing everyones conditions are different.I have a MrCool 12K 120V minisplit that averages around 800 watts. If it working hard, 1000 watts, somewhat idling maintaining room temperature it has been as low as 400 watts. I live in a small 1100 sq/ft house with 1 bedroom/bathroom upstairs. A Mini splits is installed in the upstairs and downstairs. It has been 100+ the last week and I still only need to run the upstairs unit (i can pull air from upstairs to downstairs). Downstairs fluctuates from 73 in the morning to 78 in the evening. I attribute the insulation as the main factor here. Underroof is spray foamed, under the house is spray foamed, inside walls is standard rockwool insulation but outside walls are covered in 3/4 thick of polyiso-insulation. Then add the tree cover! So your mileage will probable vary but I feel the mini-splits are the way to go for lower energy consumption vs a window or central unit.
Yes, its running full time, I set it on 68 and let it run. The only time its off is during filter cleanings or I had the power off a few times the past couple months for other electrical changes/upgrades. The only time I run the downstairs minisplit is when we run a freeze dryer in the utility room, that heats up the room quickly!So I assume your unit is running full time and not cycling off as its basically pulling on avg 6.6 amps. Thanks for your input, mine will be used to supplement our main ac and will be run off solar. I'm just trying to get some real time numbers knowing everyones conditions are different.
You must have not seen post number four in this thread. 120V mini split on inverter may be false economy.I didn't see a single mention of Power Factor.
