Greetings, I am new here.
My question is, what size wire do I need for a 25-30’ run between my EcoFlow Delta 2 Max and my Allpowers SP039 600w portable solar panel set?
The EcoFlow has a XT60 solar input and will take up to 1000w of solar for charging. The Allpowers SP039 specs are Vmp = 44v, Imp=13.63amp, Voc=52.8v, Isc=14.99amp, its efficiency states 23%.
Again I would like a 25-30’ wire between the two. Can I have a heavy wire connected to a smaller wire at the ends? Say, the stock panel wires connected to a 4 AWG (25-30’) then reduced at the EcoFlow device with the XT60 connector?
Any advice would be appreciated.
Thanks in advance.
JRod.
Thanks in advance.
JRod.
