Hey folks, I've got 20 300w panels about 50ft from my EG4 6500ex inverter (which is connected to 6 of the EG4 batteries in a rack). I'm ready to connect the panels to the inverter, but I'm unsure of the best way to wire my panels up. Series or parallel? Do I need a combiner box if my voltage/wattage is within the inverter's limits? And what gauge should I use for this setup to make a 50ft run?
These are the cables I was planning to use: https://signaturesolar.com/pv-wire-100-ft-10-gauge-copper-30-amp-black-red/
Do I just plug each panel into the panel next to it and then the final panel into this longer wire and then directly into my inverter's pv inputs? Seems too easy...
