Hello,
I have a SRNE HF2340U60-100 all in one inverter. It is going in an off-grid cabin, with a 120V generator wired to the AC input, 1400W solar array, and 120V AC output wired to a distribution panel. The problem I am having is that there is no ground terminal on the AC out, and I can't get any information from SRNE about how to properly ground this thing. There is a ground on the AC IN, and a ground lug on the case (see picture). Is the assumption made that the ground wire pictured here is going to the panel, which is then grounded by a rod? Or is it going directly to a ground rod?
Also no mention in the manual about neutral bonding. Has anybody else set one up that could offer some insight?
