Possible Xuba 280 Ah LiFePO4 Capacity Problem: Advise Welcome: I have my 8 3.2v * 280 Ah Cells I purchased in March, that I obtained two months later at my California USA home: ... I have 8 3.2v 280Ah LiFePO4s hooked up to two MPP LV2424 All In Ones, plus a V.4.0 Chargery BMS8T (battery and solar wall picture attached). I have now cycled the batteries about 6 or 7 times from very close to full, & then close to empty; ... recharging at 60 Amps or 120 Amps. I think the Info. via my BMS indicates I may have one problem cell with higher internal resistance, that I currently think is not producing the rated 280 Amp-Hours (on my cell # 8). I am wonder how this looks to more experienced LiFePO4 folks. This is my first time ever DIY LifePO4 build. I attached a couple of BMS screen pictures from my last draw down showing cell # 8 bottoming out early as compared to the other cells, while also showing more internal resistance via what the Chargery BMS shows me. (pictures attached).
I Note: The cell imbalance picture I got from my last draw down of battery bank IS With All the Chargery BMS8T's Balance Options Turned On (balancing during charge, discharge, and storage), while my cut-out voltage of my All In Ones units were set at 21.4 or 21.6 volts (on that last run). For my further diagnosis picture: ... I intend to finish wiring my Chargery's discharge side SSR to fully turn off my All In One Inverters at 2.5 v cell voltage (instead of trusting a slightly higher total voltage setting of my All In Ones. I want to next see what kind of BMS pictures I get from my next draw down of fully charged and balanced cells. I think I then might get further info. from doing the same after I placing the questionable cell #8, in a different battery bank position (like #2 or #3).
... I am open to feedback and advise on this curve ball.. I currently think I may have received on below par 280 Ah LiFePO4 cell from Xuba, and will have to see if or how they might help resolve my issue (unless I figure out this is from something else). Feedback and any ideas for better testing are Welcome ...
View attachment 16249 are welcome. ... Bill
