SilverbackMP
Solar Addict
- Apr 4, 2022
- 1,008
You are overlooking this: “No more than 40kWh in any one location. Location being: 1) Inside house; 2) Garage; 3) outside house.”Let's say that more wiring increase the risk of having a fire. Lots of electrical fires. Many are localized, and only damage the immediate area.
If you put two racks side-by-side, the risk is that one rack will start the adjacent rack on fire. Remember that NEC code is based upon LI, not LiFePO4. LI is notoriously hard to put out, and you just made it twice as hard. Plus you have twice as much fuel to light the entire house in a fire.
The 3 feet rule is to keep the other rack safe (assuming that it too is UL9540, and has some fire resistance).
40KWH is ok for grid tied. It’s ok for off grid should the sun always shine and/or want to live like a pauper. It’s not ok if you want normal amenities and/or have a shop.
