timselectric
If I can do it, you can do it.
- Feb 5, 2022
- 18,839
If parallel batteries. The only way to truly protect the wire, is from both ends.If you are doing more than 2 parallel batteries the fuse should be at the bus bar. If doing a single or pair of batteries the fuse can be on either end with no problem. This is how the math works out.
