sprucegum
Just sharing this fuse option for those with smaller systems considering MRBF or ANL:
Littelfuse MIDI High Performance 70V
(Available at waytekwire, mouser, digikey and other places for about $4).
It has 2,500 AIC @ 70V (Spec sheet doesn't list lower voltages, but if it functions like all the other fuses, that should mean at least 5,000 @ 32V and at least 10,000 AIC at 14V). Available 30A-200A. Same form factor as other MIDI fuses. Spec sheet says 1Megaohm of resistance in open state up to 70V (which works out to far more AIC, so I must be missing something in how that factors in).
For comparison, MRBF is only 2,000 AIC @ 58V [BlueSea spec sheet], so in theory, this fuse should perform substantially better than the oft recommended MRBF (though I have no idea why people recommend it as a better AIC option over ANL which has higher AIC when you compare them at their only comparable spec of 32V).
Anyhow, the midi factor makes it cheap, small, and a nice perk is that it can be fit into fuse-block bus-bar combo such as these:
Available at waytekwire and elsewhere...
Just sharing because I've been researching for a couple days and was very happy to find such an elegant and affordable option. The nice thing about these Eaton MIDI fuse blocks is that they interlock and can be combined. (The product series is LMI, and it's only a few bucks for each fuse block and another few bucks for the bus bar).
(My plan is to bring the battery positive in from one side through it's main fuse into the busbar, and then distribute to the inverter/scc/lvd from there with the same style MIDI fuses, eliminates a lot of wires and connections).
If you prefer to have a real cadillac of a bus bar fuse block, this one takes MIDI (and a single MEGA) and is from an actual cadillac:
https://www.ebay.com/itm/3257949265...C7OkMR3wAv7GijB4gU372XY5Y=|tkp:Bk9SR4ac58eJYw
But the cadiallac, while a bit cheaper all said and done, is topless...
