What was your most interesting recent non solar project?
Here's the only other picture I have to show how hard it shoots. Water cooler bottle before and after. I built it to look more dangerous than it was but it turned out to be more dangerous than it looks
View attachment 216213View attachment 216214
I've always wanted to make something that launches golf balls. I've had plenty of fun with walnuts in a potato gun, quarter sticks in a potato sent airborne are a blast as well...
Yours is next level.
Thanks for some inspiration
Be careful if you use acetylene for the propellant it has a sharp pressure curve. You have to account for it or you can make a metal fatigue bomb instead of a toy.
Solar Powered, Remote Controlled, Double Barrel Mortar Launcher
Mortars of the standard 4 to 5 inch mortars you can by at a fireworks stand
This launcher sits in field about 350 feet from my sons back porch.
4 Buttons on remote:
First opens hatch and arms the launcher
Second launches mortar tube one
Third launches mortar tube two
Forth closes hatch.
The hatch cannot be closed within 15 seconds of initiating a launch (give the fuse time to burn and launch)
The hatch will automatically close 15 seconds after initiating the second launch or 30 minutes after initiating a single launch.
planted some plum trees
How deep did you make the hole underneath? I worked as a gardener for 7 years and i used to plant olive trees. I used a mini excavator because they insisted we dig holes at least 120 cm deep (around 4 feet). It helped greatly the development of that tree in the first two years, making it reach a bigger size much earlier.
Gotta let those roots go free...
I love olives, wonder if I could plant them in PA; my fig does pretty good every year.
There is not much difference in latitude. The ones i worked with were in Umbria, 800m elevation and they did pretty good. During the winter we could get -10 celsius and i never saw any damage. As a gardener you always hope for a cold winter because it kills a lot of parasites making the work much easier. We used the olives to make ovile oil, there is a big olive oil culture here in Italy, there is a lot of people that make their own.
I don't like the idea of a solid linkage from breach to shoulder or wrist.
Would rather it had some travel, then a spring to return.
Would you rather ride a hard tail, or something with full suspension?
:unsure: we will revisit that answer when you have gotten 10 years older and your joints are all worn out :eek::eek::eek:
A 10 round mag and your shoulder is about done.
I would imagine, the only long gun I have ever fired other than an M-16a1 and a2 was a 12 gauge shotgun, I would guess that your rifle probably is somewhere close to that. yes? no?
Unfortunately not, i dont have olive trees of my own, but anybody that has 15 - 20 trees usually does. I was the guy doing it for the country hotels i worked for years ago. After harvesting them with a group of flunkies i just brought them to the 'frantoio', a small business with all the equipment to do cold extraction of oil from olives, and you pay them a fee derived from the weight of the olives he processed for you.
I wish I could grow an olive tree...maybe inside my Greenhouse. :unsure:
