Cool I was just about to defend my normal hammer drill since it chews thru bricks like chewing gum after reading these post and it turns out its not a normal hammer drill...
Its a rotary hammer drill![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Ive never seen anything like the difference this tool made. I'm going to make a youtube vid in a few days when I drill some more holes into a brick wall with it showing the difference of a normal drill using the same bit as drill with the rotary hammer drill.
I spent 2 damn hours trying to drill a small hole in a brick wall trying to install the cover kit for the mini split I installed last week using a masonry bit and a normal drill. I then found I had a bit that small for the sds plus the hammer drill needed. I drilled 7 holes in 60 seconds of actual time drilling after switching over.
I literally couldn't get the drill up to full speed before the hole was made.
It was like magic in comparison.
M18 18V Lithium-Ion Brushless Cordless 1 in. SDS-Plus D-Handle Rotary Hammer
